John Nordling »
https://forums.nicoclub.com/john-nordling-u8964.html
Mon Jan 19, 2004 3:22 pm
So I guess you're saying that this method works! Thanks for the response, DAEDALUS, I followed your directions last fall to replace the chain guides, one thing led to another, and oh, well you know how is goes. Maybe I'll get this thing on the road by spring.
I too used a mirror to check the timing marks on the bottom of the crankshaft. Easy job. I neglected to mention that I set the tension on the left chain by temporarily replacing the upper left timing cover and the old chain tensioner. I squeezed in the socket between the water pump and the upper chain guide as I mentioned earlier, then removed the actual tensioner and the cover. Wanted to be reasonably close to the correct chain tension when I checked the positions of the timing marks.
As for the oil pan, that job calls for patience and perseverance. I followed the shop manual, but it is verrrry light on details! So, I just used common sense. First, I fabricated a left side engine slinger and supported the engine with an engine hoist. This was easy because so much is off of the engine. Then I supported the transmission with an ATV jack, which is a very cost effective transmission jack with about twice the lifting capacity. Cost me $59 plus tax. Finally, I removed the transmission mount and the exhaust system mounts attached in the same area.
About this time I decided I needed to have more room to crawl around under the car, so I put the front of the frame on a pyramid of three railroad ties on each side, using one railroad tie under each of the rear wheels. These things really work well and give you that margin of safety when you're crawling around underneath. (Actually, I use treated highway guard rail posts cut in half.)
Now, I crawled underneath, pulled the sway bar, the steering rack, the tension rods, removed the lower suspension arm from the cross member, tied up wires and hoses, pulled the motor mounts and finally the crossmember. After that, dropping the pan was just a matter of pulling the bolts and a light from a rubber mallet.
Probably more than you wanted to know, but I just don't think there is an easy way for a DIY to pull the pan.
Thanks for listening..........John
