LAQ wrote:my q runs fine, but it runs a bit high when first started in the morning and it calms down when warmed up a bit.
Are you sure it's not just the normal warm-up cycle? It's supposed to idle high until it warms up. Then you should see it at about 600 RPM.
The vibrations you feel may be motor mounts, transmission mounts, or exhaust hangers. If they've never been replaced before, it's time. I'd replace the exhaust hangers and transmission mount first. Then go for motor mounts as a last resort (lot's more labor).
Your nearest nationally-recognized older Q Guru is Jerry Tucker in San Diego assuming you're in Hollywood CA. Your local dealer should be able to complete the injector flush and plenum/throtle body cleaning, but there's a very wide variance in how dealer service departments work.
Welcome to NICO!
Heath
