jsinatra wrote:The cd player(factory) worked for awhile, now only the lights are on...no display or sound.
This can be fixed by removing the half a** radio install and installing the OEM radio (Which by the way had no CD player in the radio but does control a CD changer in the trunk).
jsinatra wrote:The AC/Heater display doesn't work either, the actual blowers work but I can't see where it's blowing or how hard.
The HVAC controls displays go out all the time. You can try this guy:
http://www.jerrytucker.net/products/prod01.htm
Or you can attempt to fix it yourself:
zerothread/804
jsinatra wrote:Also, the clock doesn't work. All the dash lights work fine, just no displays, is there are short problem? Fuses are fine, antenna works, all that. I need to get this fixed, help me out!!
The clocks are also not fail proof so it may be bad.
But all of the above problems could be linked together somehow because of the wiring of the radio.
Here is the Service manual where you can look at the wiring diagrams: Nicoclub.com/FSM/Q45
Welcome to NICO.
