92 Q45 SHIMMY 1500-2500 RPM
BOUDREAUX
Car: 1992 Infiniti Q45
I have a 1992 Q45 with a serious vibration between 1500-2500 rpm. I have been told that the driveshaft may need balancing (can these balance weight fly off?) or perhaps one or more of the u-joints are bad causing restricted travel. Another theory is that the rear transmission mount may be breaking down causing the transmission to drop, hence putting the driveline in a bind.
What should I look for when inspecting the transmission mount? Are there any specs to investigate?
Has anyone ever had to have their driveshaft rebalanced or overhauled?
Boudreaux
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Does the vibration occur with the engine in park and in drive??? IE moving vs not moving?
96Qowner
Car: 1996 Q45
If it's a transmission mount, you should be able to determine it easily on a visual inspection - all pounded flat n stuff, from the shimmy. Mine was a mess. I had a nasty shake centered at about 2250 RPM. Replacing the transmission mount took care of it.
texasoil
Car: '92 Infiniti Q45A
'94 Infiniti Q45A
'94 Mercedes-Benz SL600
A bad driveshaft will cause vibration that is road speed related, not engine speed related. Drive at the bad speed and slip it into 3rd.If the vibration changes a lot--not the driveshatf. Maybe an engine mount or exhaust system hangers hard. A sagged transmission mount seems to cause a resonant vibration at 1500 RPM and 2450 or so. Any vibration that is present when not moving is either engine mounts, transmission mount, or exhaust system mounts.
nissanforlife
Car: 2009 Infiniti G37X
WOOHOOO!! another olathe Q-man... hope you get the problem figured out.. these guyz are really helpful.. come hang out in the infiniti general forum too... its basically Q central..
gritt
Car: 84 300zx, 00 pathfinder, 84 300zxAE, taco
grab driveshaft at the carrier bearing and wiggle. if there is a lot of movement, there you go. look out, had to replace the whole driveshaft on a friends 90 q45, because replacement bearing was moddified and NLA. over $500 and that was with employee discount.
texasoil
'94 Infiniti Q45A
Replacement center bearings and center bearing holder/mounts are available through Powertrainindustries.com. Their part # 1280-70 is for the 90-95 Q45
