mesallem wrote:.....would i be able to do them myself? is it a very complicated job. also when im in drive it vibrates a lot, but say im at a stoplight, if i throw it in neutral, the shaking almost completly disappears, is that still injectors?
It's injectors. You've got 4 bad ones, 2 marginals, and 2 good ones. Your Q is not going to run worth a darn until you replace the 4 bad ones and while you've got the plenum up you might as well do the other 2.
You can get refurbed ones for about $35/ea. Do a search in Infiniti Parts For Sale Forum for member PopPop. I'm pretty sure he's got them. The job's not hard but you better do a lot of reading here and understand what you're doing before pulling the plenum.
Don't feel bad. My 94Q parts car, which is leaving for the junkyard today, had all 8 injectors ohming at 22+. The engine ran like cr*p. Good luck.
