'92 Q45 in Southern CA. Needs Timing Chain Guides Done.
ShortSeason
Car: 1992 Q45 (Oct 2010 80k Miles)
Time to inherit the folks '92 Q. Only 50k on the clock. She lived in their So Cal garage since she was born. 100% hwy miles. Infinty has done 100% of the maintenance.
I don't think the guides have ever been done. I will check the maintenance records.
Any one know of a good shop in So Cal to get this done? I will would take her to the dealer, but I am sure that would drop some serious $. I will pay the $ to have it done right, but if there is a better shop that will do it for less...
I have been reading through all your threads... thank you dedicated members for all the info. I am sure, I will be spending $ with some of you (tower brace, chip, etc.).
Thanks!
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
http://www.jerrytucker.net
Surprised you didn't se it before.
Sounds like a wonderful car.
Q451990
Sounds like a real gem of a Q... we need pictures!
Ditto on what Brian said about using Jerry Tucker... I would take care of that before taking it home to MN.
Welcome to NICO!
Heath
ShortSeason
Thanks much for the Jerry Tucker info!I talked with them and they can do the job. They said it has been a couple of years since they have done one.Should be able to get it done in 10 hrs.
They told me to order the parts from Scottsdale Infiniti.I see the parts list on Tech Pages. Don't think I need to do the cam timing?If I order the pats listed as YES... will I be ok?
Yes- 1x 13510-60U00 - front cover sealNO- 2x 13270-60U00 - valve cover gaskets (if valve cover is removed)NO- 4x 11051-60U04 - cam end seals (if the valve cover is removed)Yes- 1x 13091-60U01 - guide (tension RH)Yes- 1x 13091-60U11 - guide (tension LH)Yes- 1x 13070-60U03 - chain tensioner (RH)Yes- 1x 13070-60U12 - chain tensioner (LH)Yes- 2x 13085-60U01 - chain guide (tensioner guide?)Yes- 2x 13085-60U11 - chain guideYes- 2x 13094-60U00 - guide boltsYes- 2x 01121-04711 - guide boltsYes- 4x 13075-60U02 - tensioner boltsYes- 1x 13079-60U01 - tensioner gasket (LH)Yes- 1x 15041-60U00 - oil pump chain (highly recommended)Yes- 1x 15073-60U00 - oil pump chain guideYes- 1x 15073-60U10 - oil pump chain guideYes- 1x 15072-60U00 - bracket oil pumpNo- 1x 15044-60U00 - crank/oil sprocketNo- 1x 15043-60U00 - crank/timing sprocketNo- 2x 13021-60U00 - crank/cam sprockets (if warranted)No- 2x 13028-60U00 - timing chains (if warranted)
The car did have the top end redone in '03: Injectors, Valve covers, Plugs, Sensors, Under plenum hoses and all parts cleaned.
Thanks much for the help.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Get the Oil pump chain (tensioner?) and front seal also.
No offense, but I hope you keep it off the MN roads when it is a salt bath.
ShortSeason
maxnix wrote:Get the Oil pump chain (tensioner?) and front seal also.
Those two parts must be missing from the Tech Page list? I will add them to my list.
NO SALT! and NO offense. I have heated storage for this baby. Summer use only.
Thanks!
