AZhitman »
https://forums.nicoclub.com/azhitman-u113.html
Wed Apr 02, 2003 10:49 am
Chris - Great questions.
First of all, allow me to welcome you to NICO. Hopefully you'll find everything you need here. Spend a little time searching the old posts and you'll find a wealth of information.
Second, it'd help to know more about the status of your Q. Overheating can be a terminal case for the Q with an aluminum engine. Beyond that, if you haven't replaced the chain guides yet, there's no need to do anything else until that's done. You may be looking at more work than the ngine is worth, most simply replace with a take-out motor. I don't think headwork is an option, and the cams are optimized for performance to my knowledge, but Q45tech will chime in here soon with the straight scoop.
Third, to address your performance questions: The Q already has headers (believe it or not), and the intake and exhaust has been found to be damn near as good as it can get. There was a member here who spent over $1500 developing a tuned exhaust system, which netted him less than 20 hp at the rear wheels. Even open pipes net minimal improvement.
Very little you can do to the Q to improve upon the factory. Some have had good results with rear gearing changes ($600 or so), JWT ECU ($500), 1st gear start TCU (junkyard), NOS (depends), etc.
Beyond that, new plugs/O2 sensors/fluids and a good intake/TB/plenum cleaning will net you more performance for the dollar than anything else.
