Wow lots of stuff here, ill try and briefly go over each one...
leosden wrote:my 92 q has 117,000 miles on it,I bought it late december with no knowledge whatsoever was done do it service wise.
1. the brake pads worn and stoplight malfunction messages are on,2. so is the antilock brake light,3. only one speaker works,4. the HVAC display is out,but comes on sometimes,5. and the sunroof switch is broken off,so it only tilts..6. As for the exterior the antenna doesnt go down,7. and trunk opens when it feels like it .8. To the engine,I have replaced the water pump,radiator and alternator.9. a humming sound from the rear back seat when im driving,10. and clanking noise in the engine compartment which someone told me might be a "arching spark plug wire "this noise is so loud you can hear it when driving,windows up and everything.any ideas on all these above mentioned issues
1. Besides the obvious (that you need to replace the pads) you can bypass the sensors by shorting the 2 wires together.. Stop lamp inoperative is also fixed most times by replaceing the high mount stop light bulbs with genuine nissan bulbs.. If that doesnt fix it, replace the sockets.. $2 for the bulbs from nissan.
2. Hopefully your ABS actuator isnt bad, as thats a spendy part! Hopefully its a sensor or something simple, but those dont fail as commonly...
3. Time to ditch the bose and get some cheap aftermarket setup (say less than 200) to get sound... Redoing the bose, IMHO just isnt worth it... So much good stuff on the market for not very much, and even lets you keep your stock head unit.!!!
4. Common item as well... Jerry tucker can rebuild them, or you can get one (on ebay right now) and hope for the best.. The rebuild is like $200 i think
5. New sunroof switch- about $30 from dealer or cheap from junkyard
6. Broken mast... Replace hte mast (writeups done on this) for about $20... Takes 30mins to replace it, very easy job
7. I had this problem on both my Qs... The little striker on the latch of the trunk (on the body part, not the lid) needs to be bent slightly to the left (as you look down on it)... 5 seconds with a pair of needle nose pliers.... That is, assuming that yours clicks butonly pops the trunk every so often.....
8. Good maintenance!
9. Fuel pump, replace that thing asap before it fries the controller. $250 for the pump, and another $500 if you burn up the controller
10 Possible, hopefully your cars not throwing a rod or something... If you dont have oem NGK plugs its certainly possible...
Also you need to look into replacing the chain gudies..... read up on it, if you dont replace them the engine will self destruct itself... No ands ifs or buts it WILL destroy itself......
Not to be mean but this is what you get for getting a used car... It doesnt konw you only paid 1-5k for the car, it still thinks its a 40,000 luxury mobile... Dont even get me started on the suspension, drivetrain, transmission coolers, and so on...
