Good morning to ALL. This may seem silly a bit but I believe in the old saying "better safe than sorry".
Here it is: I pulled the gauges off my Q last night to replace some burnt display bulbs inside. The operation was successful. I now tried to install the gauges back but there I ran into a problem. I didn't pay much attention to where the plugs (harness) were being pulled out of. So I connected the way i thought they should be. When I started the car to see if all was okay, the gauges will not work...rpm won't move, fuel gauge won't move, temperature...NOTHING. I figured i probably connected them wrongly. So I disconnected everything and left it until I find out what goes where. The yellow and the white harness seem to interchange and fit in each other's spots.
Question: What goes where? Where does the yellow or the white plug go? I normally take pictures of anything I do on the Q for re-assembly but forgot to do so last night.
Thank you.
