92 Q45 fule pump and controller wiring harness.
jjggq45
Car: 1992 q45
I need photos of the plugs for the controller and fuel pump. A mechanic made a mess of mine. I need to straighten them out to get my car running tiptop again.
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Fuel pump control unit harness:
Thank Mike (Goody94Q45) and Lino for the pictures.
Welcome to NICO.
PS: Look at the Service Manual for a wirring Diagram: Nicoclub.com/FSM/Q45
Q451990
Here's a picture of the connector that I cut off with a controller I bought recently at my local Pull-a-part junk yard.
The spice between the black wire and white wire that join into the brown wire appears to be something that was done at the factory. The brown wire is larger, so maybe it's some sort of shielded conductor that's carrying ground and 12V through the same jacket?
This controller was out of a 1991 Q, so I don't know if the color codes changed later.
Heath
Infinitiguy19
Do you know why?
And according to the FSM they look like they connect the fuel pump and DON'T go to the ECU.
Q451990
Do I know why what? Those are spliced together? No clue... I do think it's factory though. The splice and bare wire were wrapped in a very sticky blue tape, and the brown wire is branded "sumitomo" or something like that. Maybe it's the wire that feeds the fuel pump and splits back out at some point as a separate ground and positive voltage wire? I would have to have the full harness to know for sure what's going on. Unfortunately I butchered all of the junkyard units available to me, so I would actually have to clean out my trunk to research it further. If only I knew someone with lots of time on his hands with a Q that's usually disassembled in some form or another...
jjggq45
Car: 1992 q45
thanks, i will takea look when iget a chance. car is running, but don't want to burn pump up.
