kdkrone wrote:
Last, this is how I removed the ECU--is there an easier way?1. Remove the glove box door (two straps and two screws for the hinges)2. Remove the lower shroud that covers the bottom part of the glove box. (about 4 screws)
On the 90-93 you have to remove the glovebox to get to the bottom shroud. On the 94-96 the bottom shroud is only held on by clips and pops right off with no tools. On all G50's the bottom shroud has to come off to get access to the top screw holding the ECU.
kdkrone wrote:4. Remove the two Phillips head screws that hold the ECU near the door, then remove the harness connector.
....then pull out the ECU and reconnect the harness connector. Then disconnect the harness connector, reinstall the ECU and reconnect the harness connector, I can't believe the engineers at Infiniti couldn't have positioned the LED and screw so you wouldn't have to remove the ECU.
kdkrone wrote:Last, this is how I removed the ECU--is there an easier way?
No. Get the Blazt consult cable with NissanDataScan for $130 and plug in to your laptop. You'll never have to remove the ECU to read codes again.
Haven't heard from you for awhile. Welcome back.
