92 Q45 Climate control issues
Carcrzy2
Car: 2001 Infiniti I30t
1992 Infiniti Q45a
so got me a Q45a the other day and have been working out the issues but the one i can't figure out is the climate control module i know they have issues with the led burning out so i got a new one from the yard today and replaced the burnt out one and heres what happened...the new one worked for about a minute then the display went black and i turned the ignition off and turned it back on the screen came back but dimmer then went out again but would not come back at all. I am wondering why is there an underlying electrical issue or what checked all fuses non are blown? any idea what my Q is doing? Thanks!
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Its very unlikely that your car is killing the HVAC (A/C and Heater) Control Unit. I find it more likely that the one you got was just as bad as the one that came with your car originally.
Luckily Q451990 (Heath) repairs them at a fair rate so he will come in here and respond soon.
Congratulations on finding a Q45a, is the Actsus (Active Suspension) light on?
Have the timing chains been converted to metal from the original plastic?
Carcrzy2
1992 Infiniti Q45a
Paul Wall wrote:Its very unlikely that your car is killing the HVAC (A/C and Heater) Control Unit. I find it more likely that the one you got was just as bad as the one that came with your car originally.
Thanks for the reply!
When i got the car it was on but got the Type A fluid and filled the tank and hasn't come on since
as far as the chain guides i was just reading up on that issue i have no idea if they have been replaced my car has 192K kinda worried about it going to try and pull the covers tomorrow if i have time since is my second car right now.
Q451990
Here's my thread on the fix...
fix-for-1990-1993-q45-climate-controlle ... 49899.html
Heath
OwnerCS
WELCOME to the club. You came to the right place for Q knowledge.
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
Welcome to Nico! Nice to have another ACTIVE member on board :yesnod
