Postby
alarsen77 »
https://forums.nicoclub.com/alarsen77-u66869.htmlWed Oct 10, 2007 10:51 am
Hi guys i have a 92 Q45 with the sony 10 Disc CD Changer. It seems to skip a bit more with some cd's than others. Some cd's it will skip every 10 seconds or so even on a smooth surface. I am wondering is there a better unit that i can use in this car? If so would it be hard to change out? I have tried running a lens cleaner through it but didn't seem to help much. Some cd's it isn't that bad only bumps (which i would expect on an older cd changer) make it skip, but other cd's skip all the time. So any advice would be great.
Postby
qship96 »
https://forums.nicoclub.com/qship96-u3104.htmlWed Oct 10, 2007 11:45 am
90-93 and 94-96 totally different systems,90-93 was not controlled thru headunit,and required a interface in console-94-96 was integrated into headunit-the 2 are not interchangable w/o swapping decks,etc
Postby
goody90q45 »
https://forums.nicoclub.com/goody90q45-u31761.htmlWed Oct 10, 2007 3:59 pm
How about one with an FM modulator? You tune your radio to a preset FM channel and the signal comes in through the antenna. The CD changer doesn't care what head unit you have since it doesn't plug into it.
Postby
alarsen77 »
https://forums.nicoclub.com/alarsen77-u66869.htmlWed Oct 10, 2007 4:19 pm
hmm i will have to look into that. The problem is i don't like fm modulated stuff quality doesn't seem to be as good. But if it doesn't skip like crazy then might be worth it.
