92 q45 brake pad sensor bypass problem
porshapower
Car: 1992 q45
I have read the thread on bypassing the sensor on the passenger side front and rear calipers to eliminate the "brake pad worn" message. I cut the wire and twisted them together but want to make sure I did this right because my message didnt go out. My question is after cutting the wire on the driver front caliper (the 2 wires were not copper but more of a silver wire after I stripped them) I twisted together the 2 wires coming from the car. Is this right? What do I do with the wires cut at the caliper? Another thing is the rear caliper had copper wires after I cut them and stripped them?? Thanks in advance for the help! Nel
Jeff Williams
Car: 1994 Infiniti Q45t
2000 Infiniti I30t
2004 Infiniti M45
71, 72, 73, 82 & 2000 Corvettes
I know the fronts need to be jumpered. I just stripped a wire, and inserted it in the plug, then taped up the plug so I could go back ot the OEM pads, if necessary. The rears may be the opposite. Try taking the wires loos on the rear and see if that makes it go away.
porshapower
Car: 1992 q45
Thanks for the reply. I tried a few different ways but am not sure of what Im doing... Hope I dont blow the car up! Anyone have any idea on this? Thanks again.
qsiguy
Car: 1994 Infiniti Q45 Turbo
My fronts are still connected to the pads but my rear is disconnected. I did just what you said, but twisted and put connector on it. Doesn't matter what you do with the wires out of the caliper. Both front and rear are the same. If the two wires are not connected to each other, you get the indicator on the dash. If they are connected it should turn off. Make sure you have the wires tied together where they lead back to the car wiring harness and make sure you either put a connector on them or tape them up so they don't touch anything.
KwoodTheOne
Car: 91 Infiniti Q45, 06 Altima 2.5 special edition, 2003 Kawi Zx6RR
I have the brake pad worn sensor in my dash. can the sensor on the brake Be fixed or do i need to replace it. i have a running Q45 parts car i can take from i was told it was probably the drivers side.
Q45tech
Follow diagnostic display test proceedure in FSM .....page el64 pin 17 must be grounded....... looped thru in series to a ground to turn OFF message.
KwoodTheOne
So I shouldnt need a part. Lets say I paid To get my Brakes done is this something they could of easily resolved if it didnt need a Part
KwoodTheOne
So I Looked at My FSM I see Know. How Hard is it to get to the m47-Diagnostic Info Display Control Unit ? and I will Pobably Want to check the Brakes and actuall Sensor First they Seem easier to Get To and More Likely to Go out than the actuall CU. Thank you For Your Help
qsiguy
Pads should come with the sensor as they have to be replaced after worn. I'm sure some vendors don't include the sensors in the pads tho. I use Autozone Pads with the lifetime warranty and have been happy with them. They have always given me the sensors with the pads. I never have to buy pads again, when they wear out I just take them in and get new ones as I've already done two or three times in the last 4-5 years.
I woudn't worry about finding that Diagnositic info display unit unless you either have already replaced the brake sensors or have bypassed them. It's really easy out at the wheels.
ismael-robert
Car: 1994 Q45
Hey I got the autozone pads too and on the rears all I got was a new spring for the sensor. I replaced everything and am still getting the worn pads indicator. Did you get something else?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
welcome to NICO ismael.......
Just cut the wires for the sensor and short them together.
goody90q45
Car: 1992 Infiniti Q45 (sold)
elwesso wrote:Just cut the wires for the sensor and short them together.
Like this. Cut the wires. Discard the sensor end of the assembly. Splice or solder the connector end wires together. Tape it up real good and plug it back in. If you do this to both front and rear passenger side sensors the brake pad warning message should be gone.
KwoodTheOne
what if you like to use the sensors?
goody90q45
The sensors are great to have but they give you too much advance notice that your pads are worn and then you are stuck looking at the warning message for thousands of miles. If it didn't take out the odometers it wouldn't be so bad. Sort of like the low black ink message on my printer and then I end up printing another 100 pages just fine.
Q451990
Seems to me that the sensors are timed pretty well. I have pushed it after the sensor trips before, and find that you're about 1000 - 2000 miles from metal to metal contact.
I think it's a very good idea to short it out on the sensor side of the plug (as shown above) vs. damaging the wiring on the harness side. That way, if you (or a future buyer) ever wants the functionality as designed, you can just plug in a new sensor.
Heath
ismael-robert
Car: 1994 Q45
I must agree I got the warning and by the time I freed up my schedule to crawl under the car I was nearly at metal to metal contact too. So is there no way simply to reset the display and keep the sensor function?
