bpeesy wrote:...I don't know if this is related but I now have to push the over-ride button to get the car out of park....
It certainly could be related.
The shifter is released by a switch that is mounted to and activated by your brake pedal arm. Normally, the shifter is locked in "Park". When you press the brake pedal, the button on the switch (at the brake pedal) is pressed, releasing the lock on the shifter - - you can usually hear an audible "click" as the shifter is unlocked.
So, if this switch (or it's wiring) is bad, it is possible that it is shorting and blowing the fuse.
Check the switch. If you stick your head under the dash, near the floor boards, you should be able to find the switch mounted on a bracket behind the brake pedal arm. If you press the brake pedal with your hand, you'll see the switch button being pushed.
Give this a try.
