elwesso wrote:indeed... FWIW, you can buy a mirror with a different color and you can replace the colored part with the one off your car....
Wes, when I bashed the mirror, I sheared off three bolts that hold the swivel mechanism. Do you know if when I remove my original color (white) back to change out with a purchased one, if I will need to drill out the sheared-off bolts?
Also,is there anything tricky about removing the mirror from the housing? I have never had to change out the mirror and/or motor before.
ThanksKen K
