greg_atlanta »
https://forums.nicoclub.com/greg-atlanta-u160.html
Sun Aug 19, 2007 12:49 pm
My power locks have worked inconsistently for years, they work maybe 80-90% of the time. A few years back I looked in the service manual and saw a power lock relay in front of the airbag module in the center console, figured I'd order the part and replace it whenever it got bad. Worth a try, at least.
In the past month the power locks have barely worked at all, so figured it's time to replace it. I pulled apart the center console but the car does not match what the service manual says. There is no power lock relay sitting in front of the airbag module. There is one white connector (yellow on both ends) but there is no relay in between.
The part I got is obviously an accessory or ignition relay which is just to the right of the fuse box... but I find it hard to believe one of the relays is faulty since I should have a lot more symptoms than just funny power locks. Also, I can't tell from the service manual which relay controls the power locks (diagrams are confusing).
Anyone have any ideas?
