kdkrone »
https://forums.nicoclub.com/kdkrone-u9295.html
Fri Feb 04, 2005 5:08 am
Q45tech,
Thanks for responding. I would have no problem popping for a new thermostat; I don't know that I have ever had it replaced in the past 12 years (90,000 original miles). As I reflet on what you have written, the heat blowing from the upper vents (when I use manual) when the car is idling is about 120+ degrees; it is on the highway that it is lower. I will take a thermometer with me on the way to work today to check it. Outside air here in California is about 40 degrees.
<<<Thus you see the need for my KS or coolant temp emulator, just to get Consult/ecu to ignore these fist two common major faults>>>
Two stupid questions: 1, what dose KS stand for? 2, do you make a piece of equipment that feeds some info into the system that emulates the coolant temperature?
Not so stupid question: how difficult is it to get at the AC evaporator to clean it? (I have no children, no dogs, no cats that are ever in the car, and I am bald.. but there might still be some hair there)
Q451990 wrote: <<<Remember that you can adjust the "trim" on it upward by +5F.>>>
How is the temperature adjusted if I choose to increase it?
ThanksKen K
