Found my last emissions test results. Everything was well below allowable limits except HC ppm.
25/25 testreading: 87allowed: 103
50/15 testreading: 49allowed: 107
http://www.aa1car.com/library/tr1196.htm
"Hydrocarbon failures mean unburned gasoline is passing through the engine and entering the exhaust. The three most common causes include ignition misfire, lean misfire and low compression (typically a burned exhaust valve). Ignition misfire can be caused by worn or fouled spark plugs, bad plug wires or a weak coil. Lean misfire results where there is too much air and not enough fuel, so check for vacuum leaks, dirty injectors or a fuel delivery problem. In addition to these, hydrocarbon failures can also be caused by oil burning due to worn valve guides, valve guide seals and/or rings."
When I got the emissions done, the &%$#*&@ tech turned the car on and off several times and tried to burn up the flywheel, so that could explain some of it. But with new exhaust smell something else is up. Guess the car is getting old......
I'll be at T3 in a month or two and plan to get an injector cleaning. Is there anything else I should have checked? Or just clean the injectors and wait-and-see? Is there a manual adjustment for the air/fuel mix?
Spark plugs are relatively new. Car burns very little oil (use Valvoline Durablend). EGR has never been cleaned manually but I think that gets cleaned via BG intake cleaning process?
