'92 Q: AT to Engine Torque Spec ?
ShortSeason
Car: 1992 Q45 (Oct 2010 80k Miles)
The Service Manual lists 2 torque numbers for AT to Engine.
Transmission toEngine mounting boltsA/T to engine69 - 79 (7.1 - 8.0, 51 - 58)110 - 118 (11.3 - 12.0, 82 - 87)
I need the lower 4 bolts. M12 w/14mm head.
Just did 1st oil change on car, after driving from CA to MN. Found bell housing... 3 bolts loose and 1 missing. The car had the AT replaced under warranty years ago, but only 10k miles since then.
I will be lock tite'n these.
I need to get my signature updated, as soon as I go through the 2" of service records that came with the car.
Thanks!!
Poyzinous
Car: 2004 G35x Premium 1976 Classic Red 36 inch #18 Radio Flyer Wagon...
You don't need locktite. The 14mm go in at 75 ft lbs.
