octanevortex »
https://forums.nicoclub.com/octanevortex-u184977.html
Thu May 26, 2011 4:59 am
Unfortunately, I believe you have stripped the splines on the output shaft of the trans. Not the splines that engage with the transfer case, but the splines that engage with the carrier in the trans.(same shaft). I had this happen to me once and it sounds like something whirring around in your trans. I got on it one time pretty hard and bang that was it. The actual replacement of the shaft is a little tricky, but the main obstacle is removing that ungodly trans. Trans shops carry the shaft used for like ten bucks.
