wayneindustries »
https://forums.nicoclub.com/wayneindustries-u273986.html
Mon May 01, 2017 1:26 pm
I have a '92 Pathfinder with the VG30E engine. Head gasket shot, coolant and oil mixing and leaking out of... somewhere. Compression test showed driver side cylinders were all low. Don't have the exact numbers handy but they were all below 120. And the magic test of dripping some oil in and retesting showed better numbers as expected.
Decision time: replace head gasket, or replace engine? Pretty sure if I replace the gasket I will also need to take the cylinder heads to a machine shop per everything I've read (any idea what that should run me, btw?). Meanwhile, I can find plenty of engines for fairly cheap, 600-800 range. I've never done an engine replacement - obviously an intense job but not one I would necessarily shy away from. And on the same token, if I were to replace the engine - has anyone put a different engine into an old Pathfinder, for better power and/or efficiency?
I love the truck and would like to get it running well again, but not really in a spot to dump many thousands into it.
