Hardbody007 »
https://forums.nicoclub.com/hardbody007-u241531.html
Fri Sep 12, 2014 6:55 pm
So I have a 92 nissan pickup 4x4 it starts up and runs fine works great though all the gears but 5th it like shutters / vibrates since issue the things that have been fixed are new driveline old one was bent - all new rear spring bushings - tune up everything - new trans mount - checked the rear diff - rotated the tires - checked the timing it's right at 10deg where it should be. The problem only happens in fifth at like 45-50 mph any higher or lower it's fine shifter don't shake but goes away when the clutch is pressed in iam thinking now it's the clutch but has anyone ever had or seen this issue any help would be great thanks
