amc49 »
https://forums.nicoclub.com/amc49-u275146.html
Fri Aug 10, 2018 2:02 am
A service manual is MANDATORY for things like that, ATSG sells rebuilder type ones. You also need one for clutch pack assembly clearances, many are absolutely mission critical to get trans performance right and only bumblers simply change the clutch discs and go, it can result in a quick trans DNF. The ATSG will also tend to try to point out error places where the OEM trans seems to commonly fail, and provide fixes for them.
There can be easily 4-5 rebuild kits and all may not have the parts needed, a common ATX problem. With steels, without, with backup pistons, without, with bushings, without, etc.
I too used to yank ATX in a heartbeat to go to MTX, they are so much more fun to drive and show off in. Now though you virtually need a donor car to do switches like that because way more changes there than just the trans or mounts.
