ok, here goes.
I'm working on 2 1992 maxima's with the same problem...they are both stuck in 2nd gear (A/t) and the speedo doesn't work when driving. The speedo WILL work if the sensor is removed and turned with a drill with the key on. Both have vg30e's... tried new vss's, replaced trannys, replaced atc's with no luck. I've heard that a bad tps can do this. Anyone back this up or have any other info before i head back into it?
