mtcookson »
https://forums.nicoclub.com/mtcookson-u3042.html
Thu Feb 07, 2008 12:18 pm
What exactly is leaking... the ABS unit?
I personally wouldn't recommend getting rid of the ABS but if you absolutely wanted to... you would need the lines and master cylinder from a non-ABS Maxima at the very least. There are also some valves in the back, on the suspension, that I believe are on the ABS models that might need bypassed... but I can't remember for sure on those.
