yeah, from my ltd knowledge, yes. find out how far the spark gets to find faulty component.trulyphly710 wrote:So the car should still start right up right?
there are 2 fuel lines that attach to the fuel rail on the intake manifold. if you get them mixed up then it will cause a no start problem because one is fuel in and the other is fuel return(to tank).so obviously, if you had the fuel return to the fuel in on the rial, then it wont be getting any gas.trulyphly710 wrote:I had just rebuilt the block. and i put everything back together. everything was lined up perfectly but i am running across this problem now. do u mean the fuel lines by the rail?
Thanks
The plug connects to the harness for the knock sensor.trulyphly710 wrote:it looks like the one plug right below the one you circled in yellow. But i just cant seem to find where mine would connect to.
Is there a wire that comes from some where else to connect to it? Thanks
The motor should still start up without the knock sensor in the circuit. Check the output of the coil for a spark; if no spark, check the harness connectors for the coil, power transistor, and the crank angle sensor.trulyphly710 wrote:So the car should still start right up right?
Do you have a picture of what you mean by this? Thanks again!LayNLow240 wrote:there are 2 fuel lines that attach to the fuel rail on the intake manifold. if you get them mixed up then it will cause a no start problem because one is fuel in and the other is fuel return(to tank).so obviously, if you had the fuel return to the fuel in on the rial, then it wont be getting any gas.
Yes, the crank angle sensor is in the distributor.trulyphly710 wrote:i thought the crank angle sensor was in the distributor?
