SilGuy »
https://forums.nicoclub.com/silguy-u3525.html
Sat Oct 16, 2004 8:11 am
'92 KA24DE w/ 160k has this weird vibration at exactly around 3k rpm. Recently, I've had a fuel injector problem that caused misfiring in #1 cylinder so i changed it w/ a used DE injector(blue dotted). Could this be the culprit? I've noticed some DEs came w/ blue dotted injectors in cylinders #1 and #3 but others didn't. Mine didn't, but i changed my screwed up one to a blue dotted one. I've changed the MAF and o2 sensor so far and i've checked my distributor and its components r all workin properly. Could it be my TPS?? I know for sure it's the engine because the vibration is there while i'm not moving and I jus raise the rpm to around 3k. The vibration starts at around 2700 and go away after around 3200rpm. The vibration can definitely be felt and its louder than normal. Just feels like the engine isn't running smooth... Any opinions? Thanx in advance..
