92' ka24de to 96' ka24de swap. what else do i need?
xSnip3rMaNx
Car: 1989 240sx s13
make this simple as possible.... my motor is shot. what do i need to swap the same motor (96' 5speed ka24de) to my car (92' hatch 5 speed ka24de)? the guy is selling the motor, trans, and ECU.
thank you for your replys.
xSnip3rMaNx
Car: 1989 240sx s13
i might be buying it this weekend. depending on your answer's.
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
use all the s13 sensors and intake mani, (no butterflies, correct me if I'm wrong) also use the s13 cams for a little more power than the s14's.
biggie
First off you wouldn't want the ECU from the S14, so don't waste your money.
Search will help you as there are plenty of threads about using a S14 KA in S13.
Would want to swap the S13 intake mani and distributor to the S14 engine. And can use your S13 transmission on the S14 engine, or swap the sensors from S13 to S14 transmission.
