92 KA24de 240sx w/ video. Car wont start. Please help
trulyphly710
I went ahead and changed out the coik and the distributor.. it is all lined up.. but this is still the outcome and suggestions?
Thanks
http://s28.photobucket.com/alb...1.flv
Does it need another ground or anything? Thanks
Modified by trulyphly710 at 12:32 PM 5/25/2007
180fan
Car: 89 fastback
is the rotor on the distributor making contact with the cap? is the ignitor plugged in and connected to the cap?
trulyphly710
yes. they are all connected. the timing gun wasnt lighting up and it was connected to the wire from the coil to the distriutor to see if anything was coming from the coil but as you can see, it doesnt light up
180fan
Car: 89 fastback
well check to see if there's power going to the ignitor coil and work from there.
trulyphly710
theres no power, but i have question.
Where are the grounds on the wiring harness that leads to the coil?Does anyone have pictures or can tell me where they are at?
Thanks
