92' ka24de 240sx computer code 55 what does this mean?
Freakmech
my car wont start. its a 92' what does code 55 mean... did self diagnosis and it reads this... i have haynes manual for my car but does not cover my year in the code descriptions. please dont ask any questions... my car got water flooded i got it running again... then it stopped again... i just want to know what code 55 means for a 1992 240sx... i believe it is no malfunction... just checking is all... trying to save a little time so if anyone has a factory service manual please help.... all i want to know is what code 55 means... sorry im not being an ******* but ive serviced my own car for years i just dont have a code sheet and the FAQ does not cover my year either... thank you
Repo Man
Car: 2020 Frontier Pro4X
2003 Honda Accord
I moved your thread to the Online Mechanic forum. You should find what you need here. Good luck!
Freakmech
thank you ive been working on this for weeks now and im flipping out. the car ran fine then my girl drove it now it wont start. i think that i didnt but the starter back on tight enough so it binded up. i had to replace the celiniod... i just dont want to pull it again till i know for sure what 55 means THANK YOU THANK YOU
dabone823
code 55 means there are no problems. i did the same thing with my 92 hatch after i bought it cuz it wouldnt start.
Q45tech
All 55 means is te sensors are connected and they are providing some kind of a signal [they are not shorted or open]........whether it is absolutely correct must be determined by a consult reading.
For example the coolant temperature sensor could be reading 20-50F in error but as long as the coolant number rise for 2 minutes after a start it is deemed ok.The CAS [timing advance could be misset] the ecu uses this as the master clock and times everything correctly or in error +- 20 degees by where you set the CAS. The TPS provides a voltage of 0.3-0.5 volts when the throttle is closed as long as there is more than 0.2volts it is deemed ok not correct but ok.........etc, etc.
The OBD1 ecu were not very smart.
