nis92kat »
https://forums.nicoclub.com/nis92kat-u38061.html
Mon Mar 06, 2006 7:04 am
I have a newly finished ka-t and i am having idle issues and bogging problems at any rpm. Heres what i got.. deatchwerks 650cc injectors, z32 maf, enthalpy rom tune, t3/t4 .48 a/r turbo, cp pistons, cometic, etc...
When i start the car(cold) idle jumps between 900rpms to 1500. it just fluctuates back and forth until warm, then idle stays consistent at about 900 or so. I do not have the iacv hose hooked up into my IC piping yet but i didnt think that that would matter to much while im still getting all the bugs fixed. When i hit the gas, it wants to just shut off on me.. and the engine light comes on momentarily and after it gets to a steady idle it goes right back out. I assume this is a problem with the mafs but it is getting voltage, throwing no codes, and if i unplug it, the car really runs bad. I dont know what else it could be. I looked through the fsm and it says to squeeze the iacv hose and if engine speed falls there is a problem there, well my engine speed does fall but the hose is still sucking plenty of air in? If anybody has had similiar symptoms or knows what is wrong please respond, I have tried searching but it seems other problems are different. any help is appreciated----thanks
