Thoughtful_One »
https://forums.nicoclub.com/thoughtful-one-u29843.html
Tue Jul 18, 2006 4:54 pm
I've had this problem for a while. There seems to be a serious lack in power. It does pull, but only a little and only when driving for the first 20 mintues. After an hour or two, it def. does not pull. The car does rev over 2500 RPM. When this lack of power occurs, there is no difference between 1/4 throttle and WOT. I would even go to say that 1/4 throttle gets better repsonse than WOT. Also, when accelerating, I hear hissing or a "shhhh" sound. You can say that it sounds like a spooling turbo. What should I check? It had problems with running rich, but after the mech. repaired a wire on the MAF and replacing the O2 sensor, it doesn't anymore. Any suggestions?
