Here's the story:
1992 Hatch with S14 engine, 240/232 cams, no egr, hollowed out cat, no secondary butterfly, emissions deleted, only FPR, Iacv, and brake booster. The car has been down for almost a year due to an accident, and little money. Finally got the car back on the road. The car ran like a dream for about a week. I had installed new plugs cap and rotor when i put this motor in. The car started running like crap about 2 weeks ago.
I pulled codes on it and they were 13 and 34. I checked my ECT sensor and it was fine, but decided to replace it since the code wouldn't go away. The code consisted so i replaced the connector with a spare from another engine harness. Code 13 complete. Code 34 Knock sensor. I have checked the knock sensor according to FSM it showed fine. Even checked the wiring according to FSM, and it was fine. Since I'm unemployed, money is tight. I do side work at an independent shop around town here. But my car can barely make it half way there before i lose power. See the thing is here, when my car starts up in the morning, cold engine, it runs like a dream. It consist of no problems. But as the car warms up it starts losing acceleration. The idle drops when i push the clutch in. Just to make it move i have to give it alot of gas causing the rpms to run high. I know I'm running rich, because the plugs are black now. And I'm going to replace those as soon as I can. I'm wasting gas this way. I went through 4 gallons of gas in 40 miles. Thats crappy.
I need some other brains on this. I'm good at diagnostics. But without enough relevant codes. Its nit-picking here. I know the knock sensor will retard timing, but will it cause this. And I'm not a bad technician. I have fixed many other vehicles and make a decent living doing this. But when it comes to my own car its like its alien.
In the video I'm driving down some back streets to make it home. I was coming home from the shop and had to stop twice to let the car cool before i could go again so i would have power. I show myself revving up a few times to show the car goes nowhere.
http://www.youtube.com/watch?v=tsjssjsT ... e=youtu.be
[youtube]http://www.youtube.com/watch?v=tsjssjsT ... e=youtu.be[/youtube]
