'92 GXE Auto transmission acting up...of course.
PBfrEAk
Car: '00 Frontier (Newb) '92 Maxima (Daily), '93 Max (Donor), '91 Max (Project) '77 F-150 (Funmobile)
Alright guys heres the situation...
I drove to the GF's house in Warren, PA this past Friday. Its a 2 hour drive. No problems.
I drove it on and off here and there in Warren, no problems. Monday around noon I go to start my car, it runs like ****. It had rained the night before, and it was SUPER humid so I figured moisture must be to blame. A bottle of Drygas and an hour later and she's running like a champ again.
I go to leave her house that night to drive back home and I notice something odd is going on with the transmission. As I accelerate, it shifts right through the gears all the way down to fourth before I hit 45 mph. I give it a little throttle to kick it down a gear and nothing. So I floor it...literally...still no down shift.
As I'm driving home I stop at a gas station, shut my car off, and when I start it up, she is shifting normally again.
I'm almost home (15 min from my house approx.) and it starts doing it again as I am merging onto the interstate.
Now it constantly does it. I think its something electrical because it still shifts ok and I can downshift manually but I can't kick it down just by giving it extra throttle.
Cliffnotes:
Auto transmission shifts through gears, won't down shift if I give it throttle to kick it down.
Thanks guys!!!!
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Could be your Throttle Position Sensor. You can try cleaning it instead of replacing it. It'll require making a hole in the sealed case, though (which you can then re-seal with epoxy). I would test it for correct voltage first, though (procedure will be in the FSM).
The car shifts back down to 1st when you come to a stop, right?
PBfrEAk
Yea it shifts back down as I slow down...but it just won't kick down when I force it too with the throttle.
I'll test my voltage 1st and go on from there...thanks MoD.
Has anyone else had a problem like this??
PBfrEAk
Bump for a transmission problem!!!
