92 Guide Job-- Need chains?
theheff
Hi all-- noob here and grateful for a Q support group! I have a '92 Q w/ 140K and I am gonna take her in for a guide job. I plan on ordering the parts from Scottsdale as recommended by other NICO members, but I looked at the website and saw that the kit includes chains, as well as the guides. Being a college student on a limited budget, can I just get the kit w/o the chains or do the chains have to be replaced at this point as well?
Thanks in advance,
Heff
DAEDALUS
Car: 1990 Infiniti Q45
No need for the chains under most circumstances. They'll most likely last another 100k, maybe 150k. Should knock off just over $100 from the parts. Besides, the labor to do the job with the chains is maybe double the labor to do the job without the chains. Should make a big difference in what they charge.
Q45tech
My chains have lasted 251k [guides replaced at 100k in early 1997] and the ones on the 452,000 mile Q are as built in 1989. We rarely change chains unless they have been worn by eating the oil pump up from broken guides.
However they should be examined while doing the guides just in case.
DAEDALUS
Q45tech wrote:the ones on the 452,000 mile Q are as built in 1989.
WOW! I never would have imagined they'd last that long. Good to know!
Q45tech
Thanks to the light valves and [120 pound max] valve springs, needle bearing cam followers,etc.......low frictional losses in heads..........the oil pump consumes more power than the heads.
DAEDALUS
Funny there's such a small chain on the oil pump!
theheff
Thanks for the info guys-- big help! DAED-- you mentioned that the labor would likely be halved w/o doing the chains. Is this because the valve covers can stay on? In other words, what is the difference in what has to come off in doing with and without chain removal?
DAEDALUS
That's correct. No need to remove the valve covers to just do the guides. Maybe Q45tech can confirm, but I believe the "book" time on the guides is around 12 hours at T3, and another 6 or 7 if the guides are broken, since the oil pan then has to be removed and resealed to get all the little pieces out. It will vary by shop, since there's no published industry listing for this unique job that I'm aware of. T3 bills 12 hours, but a shop that hasn't done quite as many (or none) might feel compelled to bill more.
Q45tech
T3 [forum members price] is around $1550 for guides and a oil pan drop and clean.......sales tax only on parts. That equates to around 18 "book" hours at 68 per hour. Many times we will use more than one tech at a time to speed the process. so starting at 8 AM it could and has been completed by 5:45 PM.
PalmerWMD
Car: 2004 350Z
Q45tech wrote:T3 so starting at 8 AM it could and has been completed by 5:45 PM.
and <some> forum members have had it doen to 2 Q's at T3...
Fred.:icesangel
Q45Viper
Don't use the web site for Scottsdale, call Joe and he will walk you through what you need and email or fax you a quote for the parts, WITOUT THE CHAINS. You will be happy. No matter where you go, you will no doubt pay more than at T3, they are without a doubt the best place in the country at the best price. Expect to pay around $80 an hour at a dealer. Q45Tech may correct me here, but as I understand it if the chains are in in one piece, or if they are broken but still all hanging there and they have not fallen down you can save the expense of dropping the pan. You drop the pan to get all the pieces out if the guides have shattered and self destructed. Having said that if I had been at T3 at their price I just would have dropped the pan anyway. I just did all this a couple months ago at 128k after a LOT of advice from this board. I spent about $2200 without the pan drop at Scottsdale parts prices. the difference is the $80 dealer labor rate, discounted from $90 because I sounded like I knew what I was talking about, (thanks again, guys) Also they took more hours. Shop hard and you probably can do better than me. If you can get it to T3 from California, by all means do so, that would be best. The main thing to remember is GET IT DONE QUICK. I researched for 2000 miles, my driver side WAS broken and hanging there when they opened it up. Living on borrowed time is what the tech said. Shop for a tech that has done a bunch of these too, very important!
PalmerWMD
Car: 2004 350Z
Q45Viper wrote:Shop for a tech that has done a bunch of these too, very important!
The last one is ideal, but nearly impossible outside of MAJOR metropolitan areas.
Fred...:)
90Q45blue
Car: 2006 Honda Accord EX-L
Wouldn't Jerry Tucker (http://www.jerrytucker.net) be closer than T3? I've heard nothing but good things about him and his work. He also is very fair with price. but as others have said, still get your parts from Joe. Best prices EVER :)
Nick
PalmerWMD
Car: 2004 350Z
If I was in california I'd definetly be giving Jerry Tucker a call as well.
Fred...:)
Q45tech
T3 is happy to divide the US at the Mississippi and the Mason Dixon line. Lots of self pressure on a tech when you think about somebody waiting [on you to finish] to drive 2,000 miles........not as serious as heart surgery but more than the tech makes in a month if he has to buy and install a new engine from a slip up.
