willmoodom »
https://forums.nicoclub.com/willmoodom-u155679.html
Mon May 02, 2011 1:56 pm
well, finally im reinstalling the topend. though Ive hit a hurdle! my car is a 92 model, but im upgrading to second gen injectors. after reading on this swap, i was led to believe all i needed was the inject,rail, and including hardware, as well as the inject. harness. there was much deliberation about the plastic spacers under the bolts for the rail? but no info. regarding the rubber o-ring injector to rail mount.i assumed we used the 1st gen stuff. unfortunately the 1st gen o-ring and 2nd gen oring are different in size. both inner diameter for the injector and out diameter for the lower intake runners. do i need the 2nd gen runners to complete this swap or are you guys using the smaller orings in the 1st gen runners? how is that working out? the oring is there to keep the injector centered and in place. i hope i dont have to source later model runners for this. cars been down so long, cant remember the last time i drove it.
