92 Exhaust cam help
SilviaS14KA24DE
Car: Doriftu
Ok, I've searched, and have been confused. I just picked up a 92 (or 93) exhaust cam from the junkyard for hecka cheap. Now the questions:
Do I need to machine the cams? Or can I leave them as they are and install them?
and
How do I install this myself? I read that you have to line the sprocket with the timing chain (mark it, if that eases any confusion).
also
I bought the cam with the s13 sprocket attatched to it (we didn't have a big enough socket to remove it). Can I just leave it on and it will work the the s14 ka? Or do I remove it.
Any clear installation help would be good if someone can. I'm nub that this.
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
What other cam are you using this with???
And I'm guessing you want to use it as an intake cam....you need another to match it, unless you already have a set of S13 cams in your S14 motor...???
Let us know, then we can help.
- Brian
SilviaS14KA24DE
Car: Doriftu
It's the known mod of putting a s13 exhaust cam (91 <) and replace it wiht the S14 exhaust cam.
GlacierFreeze
Car: '97 240sx (the tortise)
Most people put s13 exhaust on s14 intake side.
Projex240
Car: Dogs , My RIDE
why not get a full set and drop them in?
:: orion ::
SilviaS14KA24DE wrote:It's the known mod of putting a s13 exhaust cam (91 <) and replace it wiht the S14 exhaust cam.
I'm well aware, and I have done many different cam setups:
Original S14 (232/232)S13 (240/248)Nissan Motorsports (248/248)JWT (256/256)
Some people do 248/232 for turbo applications...is that what you're shooting for?
Or replacing ONLY your S14 exhaust cam with an S13 exhaust cam?
That'll give you a 232/248 setup...not so good. For N/A or turbo...
You need either the full S13 set, or another S13 exhaust cam that you can drop in the intalke spot, to get a 248/248 setup...for good N/A topend with a little loss down low.
Let us know what you're shooting for... - Brian
SilviaS14KA24DE
Car: Doriftu
yeah. well i've heard of using s13 exhaust and replacing it with the s14 one. i heard it gives it more high. 248/232. Will that do any helP?
I jsut wanted to try that. But if i need 2 exhaust cams i'll find another :)
RatedR
Car: my beautiful young asian schoolgirl wife! Hehehheheeh, yes, its a "field trip". Yeah, a &q
Not to thread jack or anything, but I need Orion to look at this and see if he can help. Thanks Man!
http://nicoclub.com/zerothread?id=70718 ... xhaust+cam
