:: orion :: »
https://forums.nicoclub.com/orion-u7549.html
Wed Jul 21, 2004 2:34 pm
Hehehe...bad info about the cam and ECU thing.
S14 ECU is actually more aggressive, so it's a better match to the more aggressive cams.
Many, many, many 240SX guys use all kinds of cams with the stock ECU in S14s and S13s...
For example, I made ~160rwhp N/A with S13 cams in my '96 motor, with a '96 ECU...no issues.
Forget about the S13 ECU thing...if you swapped in the '92 motor, but kept all the S14 sensors (TPS, MAF, temp sensor, distributor, etc...), then there is NO difference as far as the ECU is concerned.
Anyway, have you tried a known good S14 ECU yet?
- Brian
