92 Door panel removal?
alarsen77
Car: 1992 Q45a, 83,600 miles
Hi guys i havae a 92 Q45 and was wondering how do you get the door panel off. I don't want to mess anything up trying to remove it.
Rex
Car: None
This should cover the how tohttp://www.carstereohelp.com/s...e.htm
DrewQ45
Car: 1990 Infiniti Q45
Pull back on the forearm rest which exposes three screws. If being pulled for the first time, it may be quite difficult to do by hand. In this case, use the inverted claw of a hammer (tape it for protection) for leverage, but keep firm downward pressure else you may scratch/tear the leather.
You pop the seat control/door handle assembly with a screwdriver at top left 'corner'.
Use two screwdrivers together (using one tends to break the clips) around the edge of the door panel to pop all the clips.
...Drew....
Modified by DrewQ45 at 12:01 PM 6/7/2007
alarsen77
thanks guys that helped alot.
cut_cutta
Car: Q45
Thanks also guys. I was trying to take my door panel off, and getting frustrated.. So I came here, did a search, and tada, it's off. Thanks for the help.
