Tknbkthrsdy4anfg wrote:Havent looked at the spring, but now i got bigger problems something in my clutch/ flywheel/ input shaft area makes a horrible rubbing noise when i floor the clutch stopped, any ideas? im supposed to drive 200 miles to the 25 hour enduro race at thunder hill what am i going to do?
The grammar is a little confusing on this, but it sounds like you are saying that there is a whirring noise when you push the clutch pedal down to the floor with the car in gear while you are stopped? If so, then you probably have a bad pilot bearing or a bad throw out bearing.
