'92 D21 --> '01 Frontier Rear Window Swap
ydfalcon
Car: 1992 Hardbody, 2001 Frontier
Hello all, been reading the forum here for a while, but this is my first post. I recently purchased an '01 Frontier to replace my beloved '92 Hardbody which unfortunately took its last ride about two months ago.
The '92 had a sliding rear window in it, whereas the '01 has a regular old single pane window. I was curious as to whether or not it might be possible/worth it to swap the two rear windows. They measure out the same and look as though a swap might be possible, but it's hard to tell for sure.
It's not a necessity that I have the sliding rear window, however, if it could be done relatively inexpensively, it would be a nice feature to have.
Thanks.
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
There is some parts interchangeability between the two models - tailgates, for instance. I wouldn't be surprised if the rear windows would swap over, but I can't tell you for sure.
RT22
Car: 1991 nissan hardbody
call a glass place and ask them if the parts are interchangeable. Aftermarket glass place, unlike nissan, if they are the same will most likely have the same part number, plus they will probably have specs on sizing.
