DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Fri Oct 11, 2002 2:10 pm
A leakdown test tool is required, in addition to a compressed air supply. The tool is basically 2 pressure guages with a hose that threads into the spark plug hole. It hooks up to the air supply and measures the supply pressure, and then you compare it to the cylinder pressure. A healthy cylinder with the valves seated should be within a certain percentage of the supply pressure. Not sure how close your engine should be, but probably less than 10% different.
