92 Code reader
akble
Car: 92 Q45, 96 Aurora Autobahn, 65 Vette Coupe, 60 348 TriPower Impala Convert
have a 92 Q45 that I need to read codes off- have a AutoXRay reader but none of my 5 connecters seem to fit- where exactly is the connecter? fuse box inside lh side dash?Evidently the 92 is not OBD-II - so I need special connecter or different reader?thanks Andy
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
akble wrote:have a 92 Q45 that I need to read codes off- have a AutoXRay reader but none of my 5 connecters seem to fit- where exactly is the connecter? fuse box inside lh side dash?Evidently the 92 is not OBD-II - so I need special connecter or different reader?thanks Andy
Well you can go here to check the codes http://www.nicoclub.com/articles.php?id=60332
And you are correct 95 and below is OBD1.
The consult connnector is in the fuse box inside the cabin and you have a laptop and a cable http://www.blazt.biz/ Or http://www.e-mance.com/
Blazt is $159 with NICO discount
E-mance is $44 with NICO discount but you have to have a Serial to USB converter
Both consult cables are able to do more than just read codes just see the sites.
Good luck
