kdkrone wrote:Just yesterday, the air bag sensor light on my 140K-old beast began slowly blinking --about 2 seconds on, two off, two on, two off, etc. I have searched through the service manual but cannot find whether that particular blinking pattern means......
Hey Ken....I've been reading through the Self-Diagnostic (using the Warning lamp) starting on pg BF-182 of my 90 FSM and I'm thinking you may have gone into the "Present Diagnosis Mode". The closest thing to 2 sec. on, 2 sec. off means NO FAILURE when in this mode. It looks like pushing the door switch 5 times within 7 seconds of turning the ignition switch to ON may take the airbag system back to the User Mode and clear the light.
Look at the "How to Alternate Self-Diagnosis" on page BF-182. You're in the center box (Present Diagnosis Mode) and need to move to the left to the User Mode. Once you're back in User Mode if there really is a failure the airbag light should flash 1/2 second on, 1/2 second off. If this happens you might as well do the complete self-diagnosis (as Heath suggested) on pg BF-182 and BF-183.
Just a hunch but since the driver's door switch starts and stops the test how's your door switch working? Opening and closing properly? Rubber boot in place? Any corrosion under the switch creating a bad ground? If in doubt take it out (one screw) and clean it up. I have a couple of spares if you find that you need one.
