'92 Active Control unit in a '94??
GreenQ45a
Car: 2012 Altima 3.5 SR CVT - Dark Slate w\Black Leather Sport\Tech\Premium
2010 Pathfinder 4.0 SE Auto - Red w\Grey Cloth Towing Pkg\Tech 1
Just recieved my replacement active CPU from redmanfx before I install it making sure they are interchangable.
They have diffrent product ID #'s but are identical.
Any input would be helpful......
GreenQ45a
It works perfect!!!
Thanxxx RedmanFX....
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
So to verify, you put a 92 ECU into a 94?
Good to know!
GreenQ45a
elwesso wrote:So to verify, you put a 92 ECU into a 94?
Good to know!
Oh yes it does!!!
It's amazing how much you miss the system after going without it.
Here's what you should do once a month drive a 1990 Ford Tempo for an hour!!!
That's all it takes to make you do anything (including rob a bank) to get the money to keep you Q45 Active!!!
I can't stand bodyroll... It is EVIL.
I LOVE my Active Q45!
I must go... I got GTA San Andreas for the PC (Finally)
I'm going to go JACK a Q45 (in the game) and put Hydro's on it!
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
Good to know!
ummm- i think you guys are talking 2 diff things. green put an activecpu from a 92 into his 94. not the engine ecu.
unless i missed something??
GreenQ45a
GQ Jay wrote:ummm- i think you guys are talking 2 diff things. green put an activecpu from a 92 into his 94. not the engine ecu.
You sir are correct!
Active Suspension CPU (dual 16bit Suspension computer) under the rear deck in the trunk.
GreenQ45a
The Engine ECU would also work the only real diff is the Active ECU starts VVT at 3100 RPM not 3400-3600 like the base and "t".
and it would run a little rich.
