slipnfall »
https://forums.nicoclub.com/slipnfall-u4227.html
Fri Apr 08, 2005 3:35 pm
Have you bleed the system recently? There are many tips and tricks to getting all the air out, search for a full explaination... Keep the front of the car as high as possible, use the bleeder screw, squeeze the hoses, heat on full blast, all these things help.
Anyways, it might be a good idea to change out both your coolant temp sensors. There's one for the temp gauge, and one for the computer. They're cheap, and pretty important IMO.
Also did you install the Tstat with the air 'dimple', at the top?
I have a cheap auto parts store special Tstat in mine, and it actually makes the car run cooler than it should be. Stock Tstat should open around 170 IIRC.
-Jamie
