toms92300zx »
https://forums.nicoclub.com/toms92300zx-u174765.html
Tue Dec 21, 2010 8:21 pm
Ok so I have a problem. I see it's apparently a common problem. here is my question. I have a misfire on cylinder 2. I discovered this by pulling off coil pack wires til I noticed no change. I tried swapping coils and then tried swapping spark plugs. Still misfire on cylinder 2. I checked compression and compression was good. all my research is pointing to either a bad PTU or a bad fuel injector. My question is what is the easiest way to tell which is the true culprit. I'd hate to tear apart everything to replace a injector only to not solve the problem. I haven't seen anything on line that tells me how to check the PTU. If you have any ideas on how to tell for sure or how to check the connection at the coil pack to even see if that connector is getting a signal. I'm in dire need and cant afford to buy every part it could be. Thanks
