ZNME »
https://forums.nicoclub.com/znme-u199316.html
Sat Feb 25, 2012 12:21 am
So I finally get the car i want.. Call the guy selling it. Meet him and the car. He tells me there is an issue with oil leaking and battery was dying, but still runs good. I buy it and drive it home. Parked it til the next day. Next evening i start the car but it was sluggish, the battery i thought. So i replace that battery with the one in my truck, just to get it started ( A friend was going to look @ my oil problem) Still didnt start but had more power. So this dumb a** turns and turns and turns it over...flooding it. Started to smell oil & gas. Pulled the dipstick and yep, gas mixed with the oil.
After a few days pass and conversasions later about what it could be, someone said its your security system. This is what you do to fix it. Turn the key this way & that way and viola! didnt work. I read on a site that someone pulled the 10amp fuse and it worked. So i did that (note i havent tried to start the car again yet). I get in the car and start it, it starts so i think yay i fixed it. So i turn the car off. Started it again about 5 mins later it starts then it shuts down in like 4 seconds. Turned the key again and it wont start so at this point i checked the spark plugs and they are saturated in fuel. But i did get spark from coil pks. Called a shop and had it towed to them. The Compression test results are
Cylinders;
1)70psi
2)95psi
3)85psi
4)155psi
5)70psi
6)45psi
They said they did a wet test and the reading was the same if not lower. So they checked the timing and its fine. They did a Compression test on the radiator/ coolant. Water came out from below. There wasnt anything in the radiator. He asked if it ran hot or if the check engine light was on when i drove it that day, the answer is no for both. IDK WHAT TO DO!! Please, offer some advice
