WDRacing »
https://forums.nicoclub.com/wdracing-u3125.html
Sun Jun 30, 2013 10:30 am
You'd buy a 92 sensor. The ECU doesn't care what motor is in the car, only what sensors are feeding it the info.
Water in your oil is a bad thing, change it out as quick as you can and then recheck it frequently to see if it returns. Use Supertech from Walmart, real cheap and it works well. I wouldn't go over 5k per change though, then again, I wouldn't go over 5k regardless of oil type.
